Shock absorber mounted to engine
C.Fuller305
5
South Carolina
I have a 1994 ford ranger 4.0 v6 and I’m in the process of doing a top end rebuild on the motor. I noticed there is a small shock absorber attached to one side of the motor. I have never seen it before and I don’t know if I should replace it. If I need to what is it called (picture shows the shock)
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,604
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It's a vibration damper
Most folks just take them off
rumblecloud
1,135
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
I have the same motor. Took mine off several months ago. Haven't missed it although I may replace it one day if I get bored.
8,374
+1 ^^^^ on all the above
When the 4.0l OHV was first used in the 1990 Rangers engineers thought a damper would be needed because of the higher torque of the 4.0l, so added the small shock absorber/dampener
It was eventually dropped
rumblecloud
1,135
48022
Ranger Splash
Stock
I thought at one point after removing it, that it might be useful as a damper on start-up to absorb some of the initial torque.
Kira
62
Champlain + Hudson Valleys
Ford Ranger FX4
Remember, if you enter your Ranger in a concours d'elegance, you want that damper there.
don4331
1,356
Calgary, AB
5.3
The 428 in the Mercury Montcalm we picked up had a chain to limit engine rotation when you stomped on it!
The rubber in engine mounts isn't very strong in tension and once separated the engine gets pretty jumpy.
gw33gp
Ham Radio Operator
547
Costa Mesa, CA
4.0 SOHC
33"
I use solid mounts in my race car. I don't care if it vibrates the car. I just don't want to waste torque twisting the rubber motor mounts and don't want weight shifting around in the corners. Some racers also tie in a bar up higher on the engine to the chassis to reduce movement even more.
