ramzzhakim
- Jun 5, 2015
- 0
- Ranger
- Engine Size
- 2.3L
I just pullted out my transmission to replace the slave cyl and noticed quite a bit of play in the main shaft. You can literally wiggle the front all about but the back end where the transfer case attached, the shaft is totally solid. (Video and picture links below) Is this okay or is it the bearing inside the transmission, If the bearing, how difficult is it to replace?
Shaft Play
https://www.youtube.com/watch?v=EYgkFEZtmXI
Codes on the Transmission
http://imgur.com/a/GxR8x
The rig is a 4x4 2002 Ford Ranger, 5 speed
Thank you for your time! Need to get this running asap!
Shaft Play
