Shackle angle
Ford78
December 2012 OTOTM
Iowa
351w
Just redid my front rear shackle mount, didnt like the last mount that i had. Added alot more beef and gave my shackles more angle. U guys think this is to much or should i make it less, every thing is tacked right now and it does have full weight on the suspension. :icon_welder:
armadillon
12
Austin, TX
When you say you changed the shackle angle, did you raise or lower the shackle mount? Otherwise if the hole is in the same spot...the shackle will always be the same angle (unless the springs progressively get saggier). I guess I need to see the before picture
Ford78
December 2012 OTOTM
Iowa
351w
The mount is new and i put the shackle mount more forward. My last mount had the shackles straight up and down.
Ford78
December 2012 OTOTM
Iowa
351w
U can see my old shackle and mount in this photo. My old way had the shackle almost straight up and down with the weight on the suspension.
armadillon
12
Austin, TX
Ahhh I see. I do like it your new way a lot more.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
That is too much angle. It needs to be right around 30-45 degres with the weight of the vehicle on it.
Ford78
December 2012 OTOTM
Iowa
351w
Wouldn't that make that lean back even more. Right now I'm at 60
railman
December 2011 OTOTM Winner
12
Madisonville, KY
I think that will be fine....
l8r, John
Ford78
December 2012 OTOTM
Iowa
351w
Just got done welding it up and putting everything back together. Took it for a little drive around the block and it rode a lot better. But it did take the front end down a little. I also think I picked the worst 2 days to do this, heat index was 110 today!
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
I looked at the photo a little better and yea, I think that'll work. The mount looks TONS better too.
Ford78
December 2012 OTOTM
Iowa
351w
Thanks guys! I have wanting to do this for a while now, just didn't like the first mount and the shackle angle was just to steep.
