Screech sound
Jeremy-b
5
Fall River mass
Ford ranger
First I wanna say thank you to the ones who helped me on my last question. But unfortunately I need some more help. I gave a 01 ranger 4.0 shoc 6 cyl. 4x4. When I go up hill or sometimes take off from a red light. I get like a screeching sound. It doesn’t do it when idling out on flat ground. Any help would be greatly appreciated. Thank you.
8,370
Your fan belt is slipping
Once that starts it will just keep getting worse because of "glazing" on the pulleys
Glazing means "glass like" so super smooth
The fan belt works by Friction, needs a good grip so it doesn't slip
Get a new fan belt first
If you are still getting "chirps" at the times you describe above, then Paint the ribbed pulleys where the belt makes contact with them this will give the belt more grip
Jeremy-b
5
Fall River mass
Ford ranger
I idle pulley and belt were just replaced. The tensioner pulley has a lot of play in it when it’s running. Could that be what’s slipping? I have a video but not sure how to send it.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Jeremy-b
5
Fall River mass
Ford ranger
SerpentineBelt for 2001 V6~4.0L~SOHC
0i840=0m021Wide * 87i38=2m219Long \ Ford# 4L5z-8620-ea \ Ford# jk6-873-ea
0i840=0m021Wide * 87i20=2m215Long \ Continental# 4060872 \ GatorBack# 6pk2215
0i840=0m021Wide * 87i00=2m210Long \ Continental# 4060870 \ GatorBack# 6pk2210 = Preferred
If Tensioner Pulley is wobbling then yes it needs replacing.
thank you for the info. I should of changed that when I did the idler pulley and belt. Because it jumps pretty good. I’m gonna start there. And replace the belt even though I just did.
Jeremy-b
5
Fall River mass
Ford ranger
Well after changing the tensioner pulley it’s still making that noise. Sorry if this is a dumb question, but is there any other pulleys that could make that noise? Can’t really tell where it comes from when it happens.
