jzranger4x4
Hey all,
I'm doing a full-width Dana 44/Ford 9 swap off a 78 bronco. These are going under a 91 Explorer Sport with Dana 35 and 8.8 stock.
For now I plan on keeping the stock drive shafts until I get cash to get custom ones made. What does it take to adapt the stock shafts to the new axles???
I am not extending the wheelbase, I just want solid axles!!! I'm tired of the P.I.T.A. Dana 35. My truck has a 4" Superlift and I'm re using those springs, so the height shouldn't change(I'm using bump stops to avoid hitting the cross member)??? If the height doesn't change neither should the drive shaft length??? I know there may be a slight change since the full size axles may have longer yoke/center sections.
If there's adapters/ parts I can use, can you give me a list so I can look into it? Or if any one has a write-up, a link would help me out.
I've read through the tech library and the forums(unless I'm totally blind and yes it happens A LOT), and haven't found a lot of info on this detail of the SAS, just how to stuff the axles under the truck.
My plan is to ultimately have 4.88 w/ lockers running 35s under the truck.
Thanks in advance for the help!!!!!!!
