Rough Idle and Shake at Low RPM's
carterja1207
I have an automatic 2001 Ford Ranger with 175,xxx miles. I know this has been asked plenty of times, but I feel that my case is a little different. The ever so popular rough idle with the 3.0 engine. It has been doing it for quite some time now. Also, my truck shakes when I hit 1500 RPM's. But it doesn't do it when the engine is cold. I can accelerate, decelerate a little, then accelerate again, and it shoots down to 1500 RPM's where it violently shakes the whole truck. But if I decelerate or put the pedal to the medal, it's fine. Doesn't do it at high RPM's, just the 1500-2000 range. Now here's the fun part. The first thing I did was get a tune up. Still did it. I have changed all filters including the fuel filter, and I also had a bad fuel injector. Replaced it, and nothing happened. I had a trouble code that said IAC. Replaced it, and once again no changes. Here comes my first solution. Had a compression test done, and one of my cylinders lost it. So I was told that I needed to get a new engine put in. So I did so. I got another v6 3.0 engine put in, with 114,xxx miles. The truck did have 175,xxx. And what do you know? NO CHANGES. It STILL shakes at low RPM's and STILL has a rough idle. I also replaced the transmission fluid, so that doesn't explain the low RPM shake. Can someone please, for the love of Pete tell me what's wrong with my truck. After I got the new engine put in, I checked the codes and one popped up telling me to replace my ignition coil(s). Would that explain it, or is there something i'm missing here? I've put too much time and money into this thing for it to still do this. Any solutions guys? I'm desperate. Thanks!
a31ford
Electronics GURU
26
Brandon, Manitoba
2.9
FWIW, I had a 3.0 ranger (older) BUT.... chased my tail for 8 months or so on a "weird shake".... the long and short of it... replaced the coil.... runs like a dream.
I would have NOT suspected the coil until one night I happened to open the hood in the dark... the coil looked like a plasma generator, all glowing blue/white from the cracks in the insulation......
Greg
