RolandTrafton
- Jul 7, 2020
- 3
- Los Angeles, California
- Ford Ranger
Hey Guys, so when I first start my 1987 Ford Ranger 2.9L V6 it deviates between approximately 800 RPMs and 1800 RPMs. A very rough idle indeed. On rare occasions, after watching the needle bounce up and down at about the rhythm of someone on a large trampoline, it gives up and dies.
I got the truck about a month ago so have been doing a series of small repairs/tune ups/restorations on it.
So far I have:
Put in New Spark Plugs.
Replaced Spark Plug Wires
Replace Distributor Cap and Rotor
Replaced Ignition Control Module
Replaced Ignition Coil
Replaced Radiator and Hoses
Replaced Water Pump
Replaced Water Pump Housing
Replaced Thermostat
Replaced Thermostat Housing
Replaced Temperature Sending Unit
Replaced Air Filter
Replaced Manifold Air Pressure Sensor
Replaced Throttle Position Sensor
Replaced Idle Air Control (Bypass) Valve
Cleaned Throttle Body
Replaced PCV Valve
Replaced In Tank Fuel Pump
Replaced In Line Fuel Pump
Replaced Fuel Filter
It took a few tries to get it to start last night, and then the same thing happened this morning.
The silver lining to this is that I’ve been learning a lot about how cars work, but I just can’t seem to get mine to do so. But maybe you guys can?
So far I have:
Replaced Water Pump
Replaced Thermostat
Replaced Air Filter
Replaced PCV Valve
