Replacing Fuel lines question
Mac Guy
SE Michigan
2.3L
So I replaced the fuel pump and filler hose on my '94 Supercab due to age and rust which cause the truck to spray gas all over the place. There was a pinhole leak on the supply tube that probably explains the rough running and lack of power. During this repair I had to cut the fuel line as the angle connector would not seat without spraying gas. I guess the o-ring dried up or it was bad to begin with as well.
I did all of this by removing the bed, not dropping the tank. I also removed the Fuel lines the hard way (Thanks for the tip about wearing safety glasses, foam plugs in ears and keeping mouth closed when disconnecting the lines!)
Here is my question....
I bought a new set of fuel lines from a Ford Dealer who cut me a hefty discount and the connectors look different. I was told that they will work for my truck as the original lines have been updated. Same length as the old set of lines. Before I try to feed them thru the frame and hook them up, should these work???
I'll try to attach pics to show what I mean. Good advice will be gratefully accepted.
Dune Runner
Alpine, Ca
Try hooking them up before you run the line to make sure they will work.
Mac Guy
SE Michigan
2.3L
I understand what you mean but I am concerned about when the lines are under pressure. Can't quite do that without feeding them thru. Has anyone else done this before?
scotts90ranger
4,368
Dayton Oregon
2.3 Turbo
as long as the gender is correct those connectors are fine, they're just the modern version, the O ring size and clip sizes are standard and have been for a long time, don't worry about it, they'll work
