Removing piston rod from clutch
Fryedbm
41
Ks
How exactly do I get that "snap ring" off? Is it easier just to break it off and find a formidable replacement?
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
you mean the rod from the clutch master cylinder under the dash?
this is how I pulled just the rod out. 1/4 ID brass tubing, slide it down along the shaft to release the spring clips.
the small end is what's inside the cylinder.
61319
scotts90ranger
4,368
Dayton Oregon
2.3 Turbo
If you mean the plastic clip on the pin on the clutch pedal, I managed to get mine disconnected without breaking it (I don't remember how though, either ziptie tails or a pick or two), but if you do break it don't sweat it, if you go to the Help! section rack thing in most auto parts stores the bushings are there for like $5...
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
Can you please describe your issue in more detail so we know exactly what you are trying to get apart this way we may better help you. Right now we can only guess as to what you need help with because your question is so unclear.
Thank you.
scotts90ranger
4,368
Dayton Oregon
2.3 Turbo
On a '99, that's the only rod in the clutch system, both posts cover one end of the same rod so hopefully that helps :)
But yes, if that isn't what you mean, do elaborate and we will try to help better...
Fryedbm
41
Ks
Ok. Ty so much
Fryedbm
41
Ks
I think I got my question answer. Ty so much
Fryedbm
41
Ks
Thank you.
Sorry I wasn't clear,however I did get some helpful responses. Ty for your reply.
Fryedbm
41
Ks
Thanx so much!!
Fryedbm
41
Ks
Fryedbm
41
Ks
Ok guys. I just wanna make sure. This is what I was talking about. Upon looking at it again I believe I could use some more clarification.
Fryedbm
41
Ks
Thanks for your help everybody! I decided just to rip the whole thing out and I ordered a new one going to start over fresh.
broncc
566
MA, USA
Ford Bronco II
5"
Giving my truck more money than it deserves.
I usually just break em off and get #6C3Z-7A581-A from the dealer.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
oops, wrong rod. sorry 'bout that.
while it's possible to pry the 2 short lock tabs open it's much easier to stick a screwdriver in there and force it off.
