Mrtin
- Oct 23, 2009
- 0
- Austin, TX
- Ford
- Engine Size
- 2.3L
Hi all. I'm in the middle of replacing my front bearings on my 1992 RWD and can't figure out how to remove the inner bearing. I've got the rotor off, with everything removed except the races, and the inner bearing.
I thought that I had removed the grease seal, though there is clearly something keeping the bearing in place. What I removed was a small flexible rubber ring that came out very easily with pliers.
The new seals I bought are larger, and consist of a hard plastic outer ring, with soft rubber in the center. It does not look like I've got anything plastic still in my rotor but assuming I have left part of the seal in there, any advice on how to get it out?
Thanks for anything you can send my way.
