Remove spray paint on interior panels
madtom421
New member
As the title states, a previous owner of my 88' tried making the red interior black. There's spray paint all over all the interior panels and dash, was wondering what the best way to remove this paint would be without damaging the original red color underneath. Mainly concerned about the metal panels.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Rock Auto 5% Discount Code: 57CD9601BD5AB4 Expires: July 1, 2019
Ranger850
That guy.
71
Tallahassee Florida
Stock 2"
Stock
LIFE
"Goof Off" - "GraffitiRemover" works well on spray paint and will not affect the plastic, be sure to follow the directions. IDK what it would do to the metal, it would probably strip it all the way down to bare metal, so be cautious.
snoranger
Well-known member
ASE Certified Tech
154
Jackson, NJ
'79,'94,'02,'17
All Fords
The guys that restore plastic r/c car bodies use brake fluid to remove the old paint.
Ranger850
That guy.
71
Tallahassee Florida
Stock 2"
Stock
LIFE
91stranger
Active member
32
ohio
FORD
Brake cleaner works too good as in you will get it down to bare metal if you are not careful. Have you thought about getting new door panels? Would be cheap and easy.
Bird76Mojo
Active member
67
Toledo, il.
2001 & 1987
4.0 - 5.0
4" Superlift
33"
Good enough
Walmart sells a non-toxic, citrus based paint remover that might work well. Just test it on a small area first to see if it discolors the plastic. My mother uses it to strip old furniture all the time. You don't even need a mask. No toxic odors/fumes whatsoever.
It comes in a jug or in an aerosol can.
GB :)
