Reassurance needed
1987ranger12394
115
Hickory NC
Is it safe to adjust my valves while the 2.9l is idling? I put new heads and all new rocker assembly on my 2.9l and the tick is killing me slowly. I cant stand my little buddy ticking its heart out like he needs help.
sgtsandman
Aircraft Fuel Tank Diver
12,663
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Any valve adjustment I've ever done required each piston be in a specific location during the adjustment and never running. I can't see how doing this with it running is going to end well.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Lol. It's somewhat safe. I have a set of valve covers I modified for the task. Odds are you're going to lose a lot of oil from it. I know I did when I tried.
Mind uploading a recording of it ticking? Should be on stone cold start, start the camera before starting the truck, and have it aimed at the engine when it fires up.
Sometimes it's lifters. Sometimes it's injectors, and sometines it's a 2.9 doing 2.9 stuff. They have their quirks ?
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I did it years ago on a friends truck... by nature of the adjusting screw... it's difficult at best to do. But it did help.
As PJ said... it will make a mess and probably smoke like crazy.
1990RangerinSK
1,312
Saskatchewan, Canada
Is it safe to adjust my valves while the 2.9l is running? I put new heads and all new rocker assembly on my 2.9l and the tick is killing me slowly. I cant stand my little buddy ticking its heart out like he needs help.
Needing to do all that work anyway, you'd have been better off to swap in a 3.0. 183,000 miles on mine, and she doesn't tick. Gets better mileage than my 2.9 did, too.
1990RangerinSK
1,312
What, WHAT?! How the <censored> did you get your 2.9 to run? All mine would ever do was WALK!!
1987ranger12394
115
Hickory NC
I did the lifter adjustment according to trs guide when I installed the heads. It's got a mild tick at idle and when it gets warm or I drive it it gets and stays louder.
1987ranger12394
115
Hickory NC
I'd have to find 1. Free 3.0
2. Free 3.0 ecu and wire harness
3. Free time
1987ranger12394
115
Hickory NC
I figured it would be messy I guess I'll just take it to someone who's got more experience with the 2.9l till then I'll deal.
3. Free time
You forgot a trans.
But early 3.0s can be run on 2.9 computers and vice versa.
1987ranger12394
115
Hickory NC
You forgot a trans.
4. Free transmission preferably a t18 with 4x4 and a 351 attached plus the driveshafts
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Hm OK. So... What are you using for oil? Filter? And new cam and lifters, or just lifters?
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Did you inspect the adjusters and push rods really close? They do wear...
Did you disassemble the rocker shafts and inspect those close also? Lack of maintenance will plug them up and then the shafts and rocker arms suffer...
1987ranger12394
115
Hickory NC
It has new push rods and rockers and rocker pedestals and rocker shaft assembly it has the same cam and lifters that were already in the block.
Oil- Castrol gtx high mile
Wight- what the manual calls for
Filter-bosh
