rear end swap question
ACostan44
Illinois
Can a 1990-1992 Ford Ranger 8.8-Inch Axle be swapped under a 98 ranger as easily as one from 1998?
Wanting to use it because of its shorter 56.50 inch length so I can use larger tires/wheels
Tugg
8
Texas
Ranger extended
The 98 requires the sensor in the rear end housing for the speedo and abs. Don't think the early ones had it.08 and newer don't either
SenorNoob
586
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
That's a negative. They absolutely do not have that sensor.
Tugg
8
Texas
Ranger extended
Are you saying the 98 doesn't have the sensor? My 99 did and it took me a while to find a rear end that did. I thought the 98-07 all had it.
don4331
1,352
Calgary, AB
5.3
@Tugg : You are correct, '98 has/needs sensor. So the '90-92 axle that OP was thing of installing has issue - it does not have hole to install sensor.
