Rear Disk swap on an Fx4 L2?
jk10sport
Oklahoma City, OK
4.0L SOHC
I have tried to do some research behind swapping out my drums for disks on my 2003 Ranger Fx4 Lvl 2. I understand that it has the 8.8 31 spline like the explorers so I wont have to do an axle swap. but Im unsure as to they are straight bolt on or if I will have to modify or add some kind of spacer, because the explorer axle is longer. If they are straight bolt on, what kind of explorer do I need to look for, or do they all have the 8.8 31 spline. I know I will have to change the brake lines, will the explorer one work? And how do I rig up the Parking brake, the truck has a manual trans so its very important. Thanks in advance for any info.
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
if you are stealing parts off of an expo, it should be mostly bolt on... as long as you go right down to the bare axle... i don't know exactly how bare they get though...
if you can get it down to something like this:
you should be able to just bolt all of the expo parts onto the ranger...
as for the ebrake, the expo will have the proper levers on the caliper, as their rear brakes have the e-brake incorporated into it, and should have the same pull length on them
and your last question, what has a 31 spline? your best bet would be check out the tech library on this site, and find the door codes for the 31 spline 8.8, i am not 100% sure the door codes will say if it's a 31 or 27 though, but that can be determined by the tube circumfrence, again, that info will be in the tech library
welcome to the site, i hope you do a how to on them, as i've got the exact same axle as you, and have been thinking about this for quite a while
also, fwiw, i would not bring home the rotors, or pads from the expo, buy new ones... though i would make sure to record the year and trim of the donor truck, will make it much simpler for buying replacement parts
85_Ranger4x4
17,904
SW Iowa
Any Explorer 95-01 has a 31 spline axle with disc brakes. Explorer Sport Tracs up until their IRS redesign are the same as well.
On my '96 axle the brakeline from the Explorer went to the drivers side caliper and then went to the passenger side. I got a second passenger side soft brakeline so I can route it from the center of the axle Ranger style. I am going to have to bend two pieces of brake line... which I think is kind of fun anyway.
My 8.8 is sitting beside my truck at this point... so that is all I can help you with. There is a lot on here if you sit down and spend a night with a search window. :icon_thumby:
jk10sport
Oklahoma City, OK
4.0L SOHC
Thanks guys. I managed to pick up a '98 explorer rearend last weekend and tried to get it done this weekend but ran into the brake issue. I think what I may do is just cut the hard line right by the brakes and flare it, then run the soft line to the anchor plate. Just not sure what size brake line I have so I can do a proper flare and get the right fittings. I did find this article on here if it helps anyone. it some good info in it. http://www.therangerstation.com/Magazine/Fall2003/Converting_your_Ranger_8.8_to_Explorer_disc_brakes.htm.
--weezl--
Law Enforcement
182
hell
are you sure on all your facts there? i was hanging out with my buddy last week, who has an 02 ST with a 4SOHC, and 4x4, and he's got drum on the back...
if you pick up a brake line flaring kit, it should come with all the different size tools, don't know the exact size though, sorry
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Some early sport trac's and some early (95-97) explorers (seen it on the sport models) had rear drum.
The brake line is 3/16" with a standard double flare.
jk10sport
Oklahoma City, OK
4.0L SOHC
sweet thanks, that was really my only hold up. because i wasnt sure about the brake size. hopefully i will be able to hit it next weekend.
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
If you've seen a 1995-up Explorer with Drums somene swapped the axle on.
Remember that people break things and often a disc brake axle wasn't available.... so their mechanic would swap on a 1991-94 drum axle and most owners wouldn't notice the difference....
but the 1995-01 brake parts are a direct bolt on to the 31-spine FX4 axles
EXCEPT for the issue with the brake lines that you've already discovered
