Wanted Rear Axle Cover, 7.5, With Drain and Fill Plug
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
Not in any rush, but would like to buy a rear axle cover for a standard 2009 Ranger 7.5 / 10 bolt cover WITH a drain and fill plug.
Planning ahead for winter projects.
Dosen't have to be one of the super duper covers, just a nice clean one. Probably would be aluminum as I haven't seen any aftermarket steel.
If you happen to see one in a JY, or have an old one that can be cleaned up, let me know.
TurboRay
8
Placerville, CA ~ Earth
'87 Ranger
2.3 Turbo ~ Bob's Log, 3" exh, Boport, FMIC, PiMP, C4 & 8.8
Slight drop + SOON electric strg & gasser-style tube frt axle
Bigs / Littles
(It) doesn't have to be one of the super duper covers.......
The only 7.5 diff covers that I'm aware of with fill and drain plugs ARE the "super duper" (girdle-style) covers, Grumpaw. .
But.......if you don't need the added strength of a girdle-cover, I'm sure you don't need to be told that there's already a fill hole at the front of the pumpkin casting AND that it wouldn't be very difficult to drill and tap the bottom of said casting for, say, a 1/4 - 3/8 pipe plug. .
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
Yup, familiar with the pumpkin filler, and did think about adding a plug.
Just looking for a used one for now...have several things/plans for winter in the garage and thought about this.
Yup, most all the aftermarket are girdle style, but some are more "stout" than others.
.38spl
48
Lake Barkley, Kentucky
6”
33x12.50x15
James 1:19
I've added plugs to my stock cover.
racsan
4,443
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
too bad you dont have a 8.8 , I have a 8.8 summit girdle cover with the fill & drain plugs. Was hoping to get a 8.8 myself when I got a 4.10 axle from the j/y but the only 4.10’s were 7.5’s. I should of swapped a 7.5 into my ‘93 and kept that 8.8 before that truck went to its new home. Dont know why 8.8 -4.10’s are so hard to find in my area.
