rear axel
menlund
my rear axel is going on my 2000 ranger 4x4 is this a hard thing to replace yourself i found a used one for $350 and would like to save some dough doing it myself just wondering what is all involed in taking it out and putting back in any help would be appriciated
MAKG
19
California central coast
IF it's the same gear ratio (there are several), the only issues are handling the weight and bleeding the brakes. It's VERY straightforward. But a complete rear end does weigh quite a bit. You'll need appropriate jacks and/or jackstands and buddies.
menlund
thanks for the info! the rearend is the same gear ratio
metalmacguyver
Yeah, I built that.
11
Plymouth MA home, Buzzards Bay MA
4.0, 7.3
it is as simple as unbolting the axle from the springs, unbolting the drive shaft, the brake line, and unplugging the rear ABS sensor.
its a good idea to put new brakes on the axle and to change the diff fluid too.
kunar
131
Toledo, Ohio
5.8l
and shocks and sway bar.... oh and unbolt the u-bolts last
No members online now.
