Ranger parts on an explorer.
eclipseguy
Oak harbor, wa
I just bought a 1991 ford explorer4.0 with a 6 speed transmission. I was going to use the motor and transmission in my 1986 ford ranger super cab it has the 2.9 with a 5speed manual. But when I got thinking about it. The explorer is nicer than my truck. The ranger has 4" Skywalker soft ride coils and the Broncos 2 basterd pack springs with a set of Skywalker nitro shocks and the drop brackets for the ttb. I was wondering will these fit on the explorer. From what I can see is the coils should fit. But not sure about the coils leaves and the drop brackets.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Everything should swap over. The ex is heavier so the springs may be too soft, but it won't hurt to try.
eclipseguy
Oak harbor, wa
Thank you for the response. If I do swap the parts over I'll Chang out the springs when I save up.
SenorNoob
589
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
..with a 6 speed transmission...
I'd like to know more about this.. If that's not a typo details of what it is would be VERY nice.:D
eclipseguy
Oak harbor, wa
That was not a typo. I have not got under it to look at the inspection plate. The shifts are so tight and quick I can barely feel them. I'm off Tues. I'll get under it and see.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Explorers of that vintage didn't come with anything but a 5-speed stickshift, or a 4-speed automatic. So if it has a 6-speed-anything, it definitely is something custom by a previous owner.
Would be curious about the details of that myself too.
Also be aware the Explorer rear suspension is spring-under-axle (SUA), and uses leaf springs with approx 2" more arch than Ranger leafs. So if you have say, 4" lift Skyjacker Ranger leafs, they will only give you ~2" lift on the Explorer after you've flipped the centerpins the other direction (a set of extended spring shackles can help make up most of that difference).
eclipseguy
Oak harbor, wa
Yeah it is a custom swap. I have the bronco 2 bastard pack. I would only run it till I get the new set. My truck has been down or not running well. for a couple of years now. Getting tired of not having it. It is cutting into my fishing time.
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
That transmission looks like a garden variety A4Ld 4speed auto to me...
eclipseguy
Oak harbor, wa
Sorry it has been so long. Got the lift done. And found a bumper in the junk yard .
eclipseguy
Oak harbor, wa
I can count at least 4 shifts but I think I feel 5 but the last one is really weak.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
it has six shifts that are perceptable, 1-2-3-3locked-4-4locked.
but it is only a 4 speed gear wise. the converter lock up seems like and is effectively a baby gear.
