question on a code 211- PIP sensor
95MEXIFORD
i pulled 2 codes on my 1994 2.3 5-speed ranger. 1- 172- o2 sensor lean(probably cause i have an exhaust leak), 2- 211-pip circuit failure. so does that 211 code mean i need to replace my crankshaft position sensor or what? any help fellas...?
trail B2
8
North Eastern Ca.
Did you search the codes themselves? I always search the number it's self make sure you use the whole number.
Roger510
4
94538
Mazda B2300
I've got the same code on my 94 b2300 2.3 5 speed manual. At first it was a ignition coil circuit fault code sputtering and no power. I changed the icm codes for Ignition are clear. Now I have code 211 pip. Symptoms are sputtering and loss of power under load. Runs great in neutral. Getting ready to check out the timing and change the CPS. Hopefully that does it but I'm honestly not sure first time with this problem.
