Possible potiential for 302 block?
92ranger18
Jemison, Alabama
Stock 302
How much can a 302 block be bored over and still be strong? And what is the possible cubic inches that a 302 block can put out?
baddad457
18
Opelousas La.
Depends on the block. The Mex and D8VE blocks have thicker cylinder walls than other castings. All others will go to 30 or 40 over without issues.
originalnitro
West Blocton,Alabama
347
The only way to know how far a block can be overbored is to have it sonic tested so you know how thick the cylinder walls are. My machine shop want go any thinner than .150 on the thrust side of the cylinder wall.
92ranger18
Jemison, Alabama
Stock 302
i have an extra block laying around but it has been dropped on the ground, will that hurt it. And how do you tell what block you have?
originalnitro
347
How far did it fall?
ID mark are on the side of the block around were the starter would be.
92ranger18
Jemison, Alabama
Stock 302
it didnt fall far less than 3 feet and it didnt fall on a shop floor just the ground outside
baddad457
18
Opelousas La.
As long as it didn't land on concrete or rock, it'll be fine. One thing to watch though especially on roller blocks is how you move them around, the thin casting surrounding the rear seal on the main cap of the roller blocks (and the flat tappet 1 pc seal blocks)is easily broken. Not that it's a big deal as the oil pan will hold it in place. But not so for the 2 pc seal block caps. Break it and you're screwed.
baddad457
18
Opelousas La.
The casting numbers are above the starter for most, but some of the roller blocks have this cast on the bottom rear edges ahead of the bellhousing. The casting numbers contain "6015" in the middle, this is Ford's part number for an engine block. The Prefix and suffix is what differentiates one from another. The first two characters indicate the (model)year and decade when the part was originally started into production.
92ranger18
Jemison, Alabama
Stock 302
ok wat would my block bored .30 over with a 3.4 in crank, 5.4 in conn. Rods flat top pistons, AFR heads with 205cc intake runners 58cc combustion chambers 2.08/1.60 int/exh. Z303 cam with 1.7 roller rockers and a tunnel ram intake make? Would this be a good combination of part for a possible nitrous or blown motor
originalnitro
347
The frpp alphabet cam(z303) are junk. They are a 30+ year old design. Cams have come a long way since they were designed. There are a lot better cams out there for the money. I would go with a custom cam with that parts list it would be cheaper in the long run. Ask me how I know.
The compression would be to high on a 347 with flattop pistons and a 58cc combustion chamber to run boost on pump gas.
With those parts and a custom cam I would guess around 425 to the ground.
baddad457
18
Opelousas La.
I agree with Nitro on all but his feelings on the Z303. Junk ? Not hardly. I'm running one in my 331. Great cam. Power comes in at 1500 and pulls like a freight train to 6500.
The lopey idle will fool you, it sounds great, but it's tame enough for a daily driver. To run boost or NOS, you'd need to lower the comp ratio in a 347 by going to a dished piston.
