Poll: Which is better??
Poll: 9" or 10.5"
  • 9" center
    Votes: 6 50.0%
  • 10.5" center
    Votes: 5 41.7%
  • other and why
    Votes: 1 8.3%
  • Total voters
    12
  • Poll closed .
Todd
HCT
12
Troll land
BIITR
Solid Axle Swap 4x4
If going 40ish tires sterling.
Weld the carrier. With 5.XX gears you will like the bigger pinion of the sterling on comparison to the 9".
I love sterlings, shafts are stronger then 14 bolt by Randie's specs and more clearance then a 14!
Maverick
FoMoCo MoFo
17
Eureka, California
Refer to post #1. It will be setup as a full floater axle, it will have 35 spline full float axle shafts (which will require the 3.250 bearing 3rd member), 1350 yoke is the biggest you can get for a 9" ( I wanted a 1410 or 1480), and the minimum carrier I was planning to get was a nodular. I am thinking about the sterling route though (now)...
SVT
So the real question is do you want to spend $2500 or $500?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Neither, where I shop, the price of either axle housing is the same, and I can build either one for less than $500...
I was thinking the 9" center cause of the third pinion support, max ground clearance, and the cheap availability of a spool. If for whatever reason I wanted to go back to open I could change carriers rather than source another due to it being welded. Now I can't argue that the lincoln locker is the most cost effective way to spool any axle (which is why I'm now thinking the sterling). I am narrowing the axle, which will in turn make it slightly stronger as the tubes and shafts won't have as long of a torsional twist to them, which also brings up that either axle I choose I will have to fab. 538's is what I'm looking at, since this is my limit of choice at this point...
SVT
Maverick
FoMoCo MoFo
17
Eureka, California
If you can build that 9" for $500, you must already have nearly all the parts...
Yes the 9" will have better clearance, but you can shave a 10.25 and have nearly the same clearance. Like previously mentioned, the third pinion support on a 9" is needed, where as the 10.25 it is not because of pinion size and proper bearing placement.
86 slo-vo
02/2011 OTOTM Winner
36
owensboro, KY
you cant build a 9in the right way for $500...
go sterling, gears weld it up and done... K.I.S.S. principle is in order
