Plugging jump seat bolt holes?
Woogie
15
Boise, ID
Mazda
2.3
I'm in the middle of replacing the carpet in my B2300 and have decided not to reinstall the side jump seats. I'm concerned about water kicked up from the tires possibly seeping through the bolt holes. Is it OK to fill them with silicone?
ericbphoto
Overlander in development
16,667
Wellford, SC
6"
Sure. But why not just put the bolts back in them?
Woogie
15
Boise, ID
Mazda
2.3
I'm putting down soundproofing material and it's better
if the surface is flat.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Put down the matting, cut holes for the bolts and install bolts.
Silicone will work but if you ever decide to reinstall the seats, silicone holes will be a PITA to get out. "Murphy's Law" not mine.
ericbphoto
16,667
Wellford, SC
6"
I would probably cut some bolts to about 1/2"-3/4" long. Then use a hacksaw to put a screwdriver slot on one end. Apply blue or red Loc-tite and install until top is flush with floor.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
I would just leave it.
sgtsandman
Aircraft Fuel Tank Diver
12,711
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Do the bolts go through the floor? If so, why not install them upside down? Meaning, crawl under truck and run them up instead of down? You could use washers to space them back so the ends don’t poke up and silicone over the bolt heads if you change your mind later.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,513
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Determine the size and thread pitch and install set screws....
62788
OR...
Determine size and install push pins... christmas tree pins... whatever you want to call them.
62789
