2.3L ('02-'11) Please help me
Rangerdanger559
Mustang559
Ford ranger
I have a 2007 ranger 4banger 5 speed I got it from a family member it starts rarely when it does the gauges will go on and off but still drives when it doesn’t I get a pats code 1:6 I’ve replaced the relay no dice I’ve got a new key no dice I need this thing to get on the road please someone has to know something
8,370
PATS Code 1:6 means you are losing electrical power in the cluster, and if gauges also go on and off that would confirm that
So you have a voltage issue
First thing would be to clean battery terminals and cable ends
Test battery with volt meter, don't care if its brand new or 10 years old, TEST IT
Key OFF and after battery has sat unused for at least 4 hours, longer is better
12.8volts is a new battery
12.5v is a 3 year old battery
12.3v is a 5/6 year old battery and time to shop for battery sale
12.2v or less is bad battery replace it <<<this would be the problem
Pull out, clean and test fuses 9, 10, and 33 in cab fuse box
sheep herder
1,024
sheep pen
If it ain't broke, break it.
I had no idea Ford put a 2.8 in a 2007 Ranger.
8,370
The forum you posted in is the 2.8l forum
2007 Ranger is 13 years old, so should be on its 3rd battery, but could be end of life on 2nd battery
After testing battery voltage try to start engine, test battery with engine running, should now be 14+ volts, but under 15 volts
That means charging system(alternator) is working
Rangerdanger559
Mustang559
Ford ranger
If I can get it to start I will definitely check that out because of the pats 16 it doesn’t even crank right now
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Thread moved to the 4-Cylinder forum and marked with the engine type.
Rangerdanger559
Mustang559
Ford ranger
Update the truck is running and driving great!! Thanks for all you help @RonD ot keeps randomly shutting off thoe but fires right back up light get dim and it dies but doesn’t hesitate to fire right back up
