Photos of Lifted RBV's With Different Lift & Tire Sizes
derekj
Squamish, BC
Ranger 4wd
88 B2 - 2" coil spacer and rear add a leaf. Running 30x9.5/15 Goodyears. The only rub I get is the right front tire slightly rubs on the sway bar at full lock.
Derek
du510
Stuck between NYC & Boston
MAZDA
1994 B4000
Front: 6" SJ Coils & 2" Spacer, with 6" SJ Dropbrackets
Rear: 6" SK Leafsprings, stock block & stock shackles
Tires: 33x12.5x15
Front Wheelwell Height: 40"
Rear Wheelwell Height: 42"
I can try to get some straight-on side shots tomorrow, if ya want.
Thumper113
Colorado Springs
'94 Ranger
Skyjacker 6" Class II System (equivilant to 4.5" because it's on an X-Cab)
3" Body Lift
36x13.50-15 Iroks
Prerunner fenders, because I didn't want to trim the fenders. They clear front & rear whhen stuffed, no rubbing.
sweetsride
Terrace B.C.
2.9l
1987 B2,36"x12.5TLS Full width D44 and9", 5"susp. lift, 3" body, widen the fenders openings a bit.
Kris
Toreadorranger
5
Sal
2000 4x4 RCD 5" Suspension with 33x12.5x15 Xterrains.
CJREX
8
N. GA.
2.3 EcoBoost
2.3
http://www.cardomain.com/ride/3016822
I can not figure out how to post pictures yet. It is driving me crazy.:c-n:
Click on the picture on your Cardomain page.
Right click on the enlarged picture and select "properties"
Highlight and copy the http address
In your post here, type and then paste the http address immediately at the end of the bracket.
Then type at the end with no spaces between the img brackets and the http address.
danger03ranger
Birmingham, AL
I just put my body lift on this weekwnd. How yall like it?:icon_hornsup:
Thanks, CJREX.
stock with 265x 75x 16r tires. Roughly 31x 10.50
3" body lift with 265x 75x 16r tires. Roughlt 31x 10.50
danger88ranger
ohio
2.9
This is my 88 2wd with a 3 inch body lift and coil spacers. The only rubbing i had was on the front of the front fender, but i cut that off so it's not a problem. It has 31x10.50x15 superswamper tsl's on 15x8's.
ryanj1022
Newton NC
2.9
1987 B2. no lift. 235/75/15(30/9.50/15) tires. hard drivin and flexin without ever rubbing
98ranger4x4
Las Vegas, NV
98 4x4 cranked t bars, no lift. 15x8 wheels with 31x10.50x15 bfg a/ts no rubbing at all.
alaskan155
6
washington
FORD
7.3l/4.0l
man looking at some of these B2 didnt relize how much my b2 was sagging in the back
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
1994 Ranger:
2.5" Rancho suspension kit, 32x11.50R15s on stock 15x7" alloys
6" Skyjacker suspension (5" actually, due to the weight of the winch & batteries)
33x12.50R15s on 15x8 wheels
1990 Bronco II:
This is with 5" lift (3 suspension + 2 body), although the rear was still a bit low at maybe 3.5" here, 35x12.50 R15s and trimmed fenders
Another shot, this time closer to 6" total lift (5" rear) (sorry not much of a side shot, but still seems to show the tire clearance pretty good)
GatorBlue92
Gulf Coast, MS
2002 Ranger Edge 2wd 3.5 Fabtech Spindles ProComp AAL's & chevy Beltech Shackles with 15x8 Rock Crawler wheels and 33x12.5 BFG A/t's
pimtool
prosperity,SC
1990 super cab, 1" coil spacers and explorer leaves, 2 to 3" off of the fenders.32/11.50/15 swamper SSR's
with 6" lift and extended arms
