Permanently cover cowl vent...
Dlillie87
7
Florida
Ford/Ranger
Probably a unique situation...just looking for opinions on how one might accomplish this. I have an 86 ranger that I'm basically turning into a "hot rod" build. I'm gutting everything that isn't essential, including the entire HVAC box and all the vents except defrost,which I'll hook a small electric heater to. I want to permanently cover my cowl vent under the windshield. I know I could just cut it out and have someone weld sheet metal in its place. I'm thinking Bondo would crack. Has anyone done this, or think they have a good idea on how to?
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,797
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I haven’t noticed anyone doing it. I agree that bondo probably won’t hold up long term and access to the bottom side of the cowl isn’t great. Cutting and welding might be the best option.
One thing to consider is air flow. Without the cowl vent, good air exchange in the cab might be a problem unless you plan to address that in other ways.
Dlillie87
7
Florida
Ford/Ranger
My biggest concern is without the HVAC box, the cab would be exposed to pretty much anything that comes through the vent. As far as air exchange, I'd probably just use my vent windows unless it's raining or something. Idk what the best solution is.
sgtsandman
Ham Radio Operator
12,797
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
You should be able to make a panel to cover the hole in the engine bay. I don’t think, but I don’t know for sure, that the box doesn’t protrude into the cab. I think it gives a place for the condenser to be. The heater core might be in there as well but it’s been a good while since I’ve worked on a Ranger that didn’t have A/C. I may remember incorrectly that even the non A/C equipped Rangers had a protrusion into the engine bay.
Since you are talking about removing both, you should be able to just block off the hole in the fire wall and be able to leave the cowl vent alone.
sgtsandman
Ham Radio Operator
12,797
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I’m drawing a blank on the member’s name but there is at least one other guy that has a Ranger rigged for racing and I believe they have a build thread in the mini truck forum about it.
Dlillie87
7
Florida
Ford/Ranger
With the inner and outer box removed, there are 2 big holes that I can easily cover with sheet metal and seal them off. But there's still a hole under the dash area where the cowl vent area dumps, I don't have a picture of that. I could probably seal it off there, but then I think the cowl area wouldn't be able to drain and may cause rust problems, idk for sure
67570
sgtsandman
Ham Radio Operator
12,797
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I’m trying to find the member I have in mind so you can check out what he did with his. Harder with a phone than a computer.
EDIT: I can’t find him. He’s featured on the 2020 calendar. I’ll have to look up the name and go from there.
Dlillie87
7
Florida
Ford/Ranger
I appreciate your time, thanks
superj
2,714
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
for the cowl vents, can you use something from a wrangler? not sure if the size is close enough but lots of wranglers have covers or scoops over their cowl vents because of lack of air flow or water intrusion, different issues and such. maybe it would fit? try googling it? maybe two, one for each side?
8,374
Remove the inspection plates on the firewall, that will give you access to the back side of the cowl, i.e. windshield wiper access
You should be able to insert sheet metal pieces and screw them in place from the top side, silicone seal it
Then bondo
Would cutting cowl out and welding a new piece in be better, yes
Yes, the fresh air vent is located under the cowl right above the fan hole in engine bay
Just below that, in the cab, was the "re-circulation" vent door, it closed the Fresh air vent off and opened inside cab air vent, this was used for MAX AC but also on dusty roads so no outside air came in but you still could have fan on
Since you are not going to use the factory fan then you don't need to do anything really
If you can reach into the cowl area far enough you could try to seal off the fresh air intake, or do it thru the fan hole before you seal it up
sgtsandman
Ham Radio Operator
12,797
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Maritime Drag Racing
889
Sydney, Nova Scotia, Canada
355 Chevrolet
2" drop rear shackles
27 X 5 X 15 Hoosier front - 9X30 Hoosier rear(slicks)
Race it - Break it - Fix it - Repeat
That is who I was thinking of. Thanks!
Not sure exactly what the previous owner did the firewall on our Ranger but I think the openings are just covered with sheetmetal.
68367
8,374
It looks like they are there, inline with each wiper knob, thats what they are there for, to access/service wipers
You can see the indented part of the plates in the picture
Center of engine bay top(behind the hose), and drivers side next to inner fender, right inline with driverside wiper knob
The heater box holes have sheet metal cover
19Walt93
4,500
Canaan,NH
351
3"
235/55R16
I used a Vintage Air system because my truck was formerly drag raced and the HVAC was missing. Vintage doesn't use outside air, they just recirculate so I blocked the air inlet under the right side of the dash with sheet metal and seam sealer. Vintage Air is in Texas, they couldn't understand why I'd want to draw outside air into my truck. I guess they never had to clear a fogged windshield on a 40 degree rainy day.
