Passenger Axle Seal
l1ft3d
Alright I have a 1999 Ford Ranger, 3.0, 4x4, automatic. My problem is the seal that goes between the cv axle and the half shaft appears the be leaking. Ive tried to find schematics and walkthroughs but I must be missing everything.
Axle wise I do believe it is the D-35. It has the TTB suspension.
If someone can direct me to a schematic, part number, or anything that would be appreciated.
My only lead is the Timken part number 710428 from autozone. Not sure if thats what i need or not.
Thanks in advance to any help.
Earl43P
38
Farmington, Pa
Ford F250 4WD
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Go to the parts store and ask for the passenger side outer axle seal. I forget the national number but they're around $15. Very easy to change as well.
Hooligan2c
Law Enforcement
Tobyhanna PA
4.0 SOHC
x2, Brinker showed me how to do it! it is pretty simple, you will have to pull the hub, knuckle and CV out to replace it. When you put it back together, make sure you use a brand new spindle nut for the CV, you can not reuse those so grab that at the auto parts store as well. Don't forget to get an alignment afterwards too.
l1ft3d
Thanks everyone, also whats this spindle nut everyone is talking about? There arent any on the end of my cv axles. There tare those plastic clip things inside the hub i know.
Earl43P
38
Farmington, Pa
Ford F250 4WD
He's talking about the 2000+ "live axle" set up, same as a FWD CV joint.
Yours differs. Are we talking about the excluder seal? No need to get it aligned for that replacement unless you replace the OTR or LBJ or UCA.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
You have the vaccuum hubs so you wont need new spindle nuts. Also you dont need an alignment after removing that. It's just bolt on parts that have nothing to do with your camber/caster.
l1ft3d
Im not sure the prope name for this seal, I just know right where the cv axle meets the half shaft its leaking so thats the seal i need.
Earl43P
38
Farmington, Pa
Ford F250 4WD
Where the axle meets the differential? Sorry, I was looking at the hub end.
Gonna be either 710428 or 710429.
Hooligan2c
Law Enforcement
Tobyhanna PA
4.0 SOHC
Yup...my fault dude, sorry. I thought it was the same setup as mine
