on board air
olranger
illinois
2.9
does anyone have on board air that they use there a/c pump and install a tank somewhere on the truck. and if so lets see pics
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I do on my 91...the stock style sanden compressor doesn't like it one bit, doesn't matter how much oil you run through it it seems...I change it out once a year because it ends up seizing. Working on mounting a York 210 under the hood now.
holyford86
Some guy with a problem
619
Plattsburgh, NY
many
33x12.50R15
I just used a York 210 right from when I got the idea. Works well with little maintenance, all I do is add oil every once in a while. Because even with the york oil mod it still passes a bit of it.
I actually had to swap the pressure and suction sides when I did it, to reduce oil consumption (when laying a york on it's side it's recommended that the suction side be on the top) It involves pulling the head and valve plate, installing new gaskets, shaving down the dowel pins so they do not locate themselves into the compressor itself, only the head, and doing the york oil mod so you don't pressurize the crankcase and blow the seals out.
sweetsride
Terrace B.C.
2.9l
i have been running a stock 2.9l ac pump for the last 3-4 years, just add oil to ever 2-3 use and im good to go!! works like a hot dam!!
Kris
B2Guy
Lafollette, TN
2.9
id like to see some pictures of this. on board air would be real nice
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
ran a york on my '61 falcon 30 years ago.actually used it to paint the car,had it idling the whole time.used the sanden types too,they work but are slow.if you have room,get a compressor from a truck with air brakes and put the electric clutch from an a/c on it-those last forever.
hondaxr650
4
Tacoma, WA
That's some ingenuity right there! Never would have thought of that in a million years. Nice work.:icon_thumby:
paranger
central pa
1996 ford range
4.0l v6 , autom
i used a york 210 compressor as well. best mod i think i have ever done. i love to wheel with "jeep guys" and they think they are the only people to ever add on board air. definetly worth your time and money. here are some pics of my install
RockRanger
7
Fresno CA
Do you have a body lift or will it clear the hood without one with it stood up like that?
I love the york on my wifes cj7. Need to get one on my ranger.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
the older style 6 cyl r12's work great. the newer style 10 cyl wont take it...different slide shoes etc...
of course the yorks are good, but the 6cyl style i used put out more then the one i had off the old dodge.
