- Oct 31, 2007
- 60
- Age
- 38
- Crawlorado
- Ford
- Engine Size
- 2.9, 4.0
I just searched through 10-15 threads on this subject and couldn't find the info I needed.
background:I have an older 84 BII tank (from a carbed 2.8) that I would like to run in my 91 ranger. The plan is to throw the 84 BII tank in the bed just behind the cab and possibly cut a hole in the bed, or lose the bed all together so that the tank sits a little lower down between the frame rails. Not concerned at all with fillerneck location, or with the setup being butt ugly, I can fab up an enclosure and worry about that later. I have to make room for the doubler and right now I am trying not to break the bank with a fuel cell etc. I know that these older models used two fuel pumps and possibly different sending units than newer rangers and BII with efi, which leads us to my question
The real issue at hand:
Can I simply use my newer pump assembly out of my 1991 2.9 liter tank and drop it into this bII gas tank lenghten the lines and be done with it? I have seen some pictures online and it appears as though the hole size for the tank may be different...if so can it be easily modified to fit?
here is a picture of my 1984 BII fuel tank for reference. 23 gallon I believe, which would be nice, i would actually have an increased capacity. Its kinda nasty on the outside but clean as a whistle inside.
