oil leak still dripping
homebuiltbikes
tallahassee Fl.
FORD
2.3 duel plug
Just had my 91 2.3 fixed? New oil pan gasket, new rear main seal. cost me about $ 1000 bucks. I was told it might drip a little from oil that had leaked before repair. Drove bout 100 miles then cleaned everything with engine cleaner then wiped everything down real good. next day I noticed a small puddle under the oil filter and dipstick area. it is oilly around the dip stick on the block and down from there. I'm pretty sure its still leakin! I looked everywhere and cant see exactly where the leak is. My repair guy is pretty good so I'm going to bring it back if I cant figure out and fix it myself. I couldnt fix the rear seal and oil pan gasket my self because I dont have the means to pull the motor. If I can figure out the leak myself i'll fix it! any ideas as to what i should try?
Sunk
125
Everett, WA
3.5 Eco
The dipstick tube could be damaged or loose. Also make sure the filter isn't double gasketed.
homebuiltbikes
tallahassee Fl.
FORD
2.3 duel plug
Changed the filter, leak fixed. Guess filter has to be a little more than hand tight.
Check that, after a long ride I noticed it was still leakin, Turned out to be a crack in the bottom of the dipstick tube. I didnt see it untill I pulled it out, Small flange agianst block was cracked. Trimmed it off and put it back in, added the inch to the top and all is good!
