odometer issues
fish
I have a '95 4x4 with a stick. I replaced the clutch a while back and the odometer has not worked properly since. The speedo is fine, but the odometer registers way low. I mean it barely moves. any ideas are greatly appreciated. Thanks
8,372
It would have nothing to do with the work on the clutch.
1994 was the last Ranger with a speedometer cable.
1995 to 1997 use a VSS(vehicle speed sensor) on the trans/transfercase, '98 and up uses VSS on rear axle.
If speedo is working then VSS is working so what has probably happened is the gear on the odometer is stripped, which is a known issue.
You do have to pull out the dash cluster.
Video here on the repair: https://www.youtube.com/watch?v=oA_n-5bVxyE
