Rat Rod Bob
- May 2, 2020
- Reaction score
- 0
- Location
- in my garage
- Make / Model
- ford ranger
- Automatic
I have not seen one about this subject exactly yet. From everything I know this is a 4.0 and it is a Injected pushrod. I say this as this engine was installed into a hot rod before I got it and so the previous owner didn’t finished the project but I investigated engine #s and that is what the different factory parts line up to.
Can you please assist me and everyone else about this exact situation.
I have looked at all the books and Internet on researching and can’t seem to figure out this engine situation. If you look at the picture below you will see that my CAM position sensor solenoid & synchronizer does not have a plug on the top of the assembly. It is located at the back of the engine, just before the bell housing. I lost spark after having it for the 1st time once I finished hooking up the wires from the Ranger wire looms/ ignition assembly. The previous owner had started this project by removing the whole drivetrain, ALL wiring inside & out and installed it into the car and then ran out of time. I changed crankshaft sensor as I wasn’t receiving signal from it after loosing spark but that wasn’t it. I also stopped hearing the initial click from the fuel pump relay when you just turn on the key. I change the relay with a new just to verify but no change. So now I have stopped as I don’t want to be a parts changer..
Are you there are certain ones of these engines that actually don’t use an actual sensor after synchronizer/oil pump shaft?
Check all of these items
-ignition coils… Ohms and voltage
-continuity of ignition/spark plug wires
-ohms and voltage at crank sensor
I have plugged in OBD1 digital reader but I am not receiving any codes as it just comes on but gives nothing when I hold and release the test button as directions state.
