- Sep 21, 2007
- 671
- Wa, Bremerton 98310
- Ford
- Engine Size
- 87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
- 2WD / 4WD
- 4WD
- Total Lift
- Ranger 5" (1½" suspension), BII 4" suspension
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 33"/4:10LS, BII 33"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
Hello,
Swapped my BII's rebuilt 2.9L into the Ranger. After rellocating my fuel tank to be hind the axle in my 87 Ranger will start on starter fluid but gets no fuel to the rail.
*I have verified that both pumps work with 12v applied
*I extended the fuel and return lines from the original tank location to the new tanks location.
*I extended to pump power, ground, sender and ground wires to the new location.
*the connector "y" where the pump power splices was dirty, especially the supply side but now thouroughly cleaned.
With the starter disabled and the pumps disconnected, I get 12v to the "y" splice very briefly with the key to the run position. Same thing happens when I go to the start position, 12v briefly then nothing. Is this normal? Is there a reason that the pump supply power stops? Is it because the pumps aren't wired in?
