New UK Ranger owner
BAZUK
Kent SE England
Ford Ranger Thu
Hello All I have recently purchased a 2009 Ranger thunder 4X4 Crew cab 2.5 diesel with manual transmission. The truck was bought from Copart with front end damage. Looks like it had a fairly heavy hit on the passenger side front wheel which had shattered the wheel. Inner steering joint on Lefthand side from back and connecting bar between joints on righthand side had broken and lower wishbone ball joint on L/H side had broken. Someone had looked at starting repairs by cutting the drive shaft. I think they might of ran out of ideas when they could not move the lower wishbone due to the torsion bar winding up. I have replaced all of the broken parts but it looks like the central steering arm might be bent. Also the axles centre distance on the L/H side is between 12 and 15mm less than the R/H side. Do the lower wishbones give before the brackets that they are mounted on give or would you think it would be a bit of each. I realise that I need to release the tension on the torsion bar before removing the bar and wishbone. Sorry for the long first message but any advice would be appreciated.
Cheers Baz
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Hi! Welcome to the site. My instinct would be to release the torsion bar tension first. But I'm not an expert on that suspension design. This particular section of the forum is for introductions. You will get better answers to your question by asking it in a section of the forum that is aimed toward problem solving steering and suspension problems or even the "general" forum.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
I'm curious as to what the "Thunder" package includes. Maybe similar to the "Edge" or "XLT Sport", I'm guessing.
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The OP is from England. Thus, why he got neat things like a diesel engine.
You might be needing to take the truck to a shop that can check frame alignment. Whether you can get away with replacing the bent parts first or not, I can't say. While I'm a handy mechanic, when it comes to repair work after a crash, I'm out my element.
BAZUK
Kent SE England
Ford Ranger Thu
I have done a bit of online investigation on truck. Its basically a Mazda built BT-50 with the Duratorque 2.5 diesel engine in it. Thunder trim is top of the range at the time it was built, A/C, leather interior and some gauges that tell me the angle of tilt and inclination of the truck. I have made a start on sorting the suspension damage but work keeps getting in the way. I have started a post on the suspension section of the forum which I will update as I go along. It looks like not that much is the same as US spec trucks.
Cheers Baz
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Yup its what we call the international ranger. It was never sold in North America for some reason.
2009 North American ranger
2009 International ranger
