BAZUK
- Sep 17, 2020
- Reaction score
- 2
- Location
- Kent SE England
- Make / Model
- Ford Ranger Thu
- Manual
Hello All I have recently purchased a 2009 Ranger thunder 4X4 Crew cab 2.5 diesel with manual transmission. The truck was bought from Copart with front end damage. Looks like it had a fairly heavy hit on the passenger side front wheel which had shattered the wheel. Inner steering joint on Lefthand side from back and connecting bar between joints on righthand side had broken and lower wishbone ball joint on L/H side had broken. Someone had looked at starting repairs by cutting the drive shaft. I think they might of ran out of ideas when they could not move the lower wishbone due to the torsion bar winding up. I have replaced all of the broken parts but it looks like the central steering arm might be bent. Also the axles centre distance on the L/H side is between 12 and 15mm less than the R/H side. Do the lower wishbones give before the brackets that they are mounted on give or would you think it would be a bit of each. I realise that I need to release the tension on the torsion bar before removing the bar and wishbone. Sorry for the long first message but any advice would be appreciated.
Cheers Baz
Cheers Baz
