new roller rockers + interference 2000 flex
pjtoledo
2,968
Toledo Ohio
Fords
3.0 2.3
first off, is the 2000 flex 3.0 an interference engine??? 'cause I'm having issues.
was running OK at 117,000 so I'm leaving the bottom alone, heads are still on.
it leaked a lot, so I did what 'ol retired guys do and pulled the engine for easier access.
it's on a stand, intake off, good view of the cam & lifters.
bought a set of SBF 1.7:1 roller roller rockers, time to see if they fit.
loosened all the rockers & removed pushrods. timing chain is now off so I can spin the cam by hand.
all the pushrods were tight, engine hadn't been run for months, the springs in the lifters were keeping tension.
new cam pedestals are only a couple thousands narrower that stock, close enough.
kit bolts are 5/16, found some CV bolts from an 82 VW that are only 5 threads shorter. good enough for a test fit.
you'll need 8mm x 1.25 -50 allen head bolts for the correct fit, grade 10.9
crank at TDC, removed #1 exhaust spring, bolted the new rocker on,,,,, now the issues begin.
there is at least 1/8 inch between the valve tip & roller. so much for a direct bolt-on. if push the rocker down it contacts the stem correctly.
with no spring I was able to move the valve and check, it would drop just below the stem wear area then hit the piston.
rotated crank a few degrees L & R, yep valve started to drop so I know valve was on the piston.
then I checked for lift, rotated the cam by hand, it took up the 1/8" gap then pushed then valve down enough to hit the piston. ?????
repeated several times. yep, the new 1.7 rockers push the valve into the piston even with 1/8" valve lash. major bummer.
notched pistons are not in the plan, nor the budget.
here's where it gets weird: put the stock rockers back in, (spring still missing) snug it down and give the cam a spin.
the freaking valve still hits the piston!!!!
either this is an interference engine or there should be a hellava lot of preload on the lifters.
any ideas?
maybe tomorrow I'll put a degree wheel & dial indicator on it and find some weak springs to test with.
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I have used some roller rockers that require a "lash cap" over the tip of the valve and also require custom length push rods. This would explain the 1/8" clearance between the rocker and valve tip.
I'm not positive if it's an interference engine or not... But it probably is. As far as the valve hitting the piston at full lift with either rocker arm... that's normal if the piston is at TDC and valve goes to full lift.
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would see if you can locate a cam card for your cam... then put a degree wheel on it with the timing chain in place. and see what you get. I still think you will need custom length push rods to get you rocker geometry correct.
pjtoledo
2,968
Toledo Ohio
Fords
3.0 2.3
I didn't have time to really examine the geometry yet, that is the angle between the stem and rocker.
the tip travel looked OK, started on one side and swept to the other while staying way from the edges.
cutting these pedestals down won't work as the height of the base is barely more than the excess gap.
that would leave them too narrow.
a little voice inside me is saying "adjustable studs" but these heads are metric and I'm not sure there are any 8mm metric SBF studs.
I'll get the dial indicator out to find the actual lift, X 1.62 and X 1.7, then bounce the valve off the piston to find available travel.
so far I've only checked the exhaust of #1, probably should do a few more to be sure.
the cam is factory, doubt there is a card for it.
and yes I know the Ranger has a different cam than Taurus'.
anybody have an engine spec page?
my 1995 Taurus books have the 3.0 info but it differs a bit from the Ranger versions.
19Walt93
4,482
Canaan,NH
351
3"
235/55R16
I have a friend who works at Napa, he's printed me cam specs for several stock cams. Know anybody at Napa?
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
649
Central Indiana
The 3.0 is NOT an interference engine.
I did a clay test when I built my engine, and with the 1.8 roller rockers, there was still over .25" of clearance between the piston and the valve. I say "over .25 inches" because that's how thick my clay was and the valves didn't put a mark on it. (engine fully assembled, turning the crank by hand)
I'm not sure what you're really trying to achieve? Just tinkering? Why does it matter if the valve hits the piston when there's no spring installed? It just seems like a ton of time, effort and work when Morana sells bolt on rockers that can be installed without any of that. For what it's worth, I'm 99% certain that Morana's roller rockers are aftermarket GM LS rocker arms with custom pedestals.
pjtoledo
2,968
Toledo Ohio
Fords
3.0 2.3
over due for an update. I'm mostly tinkering for now.
put a dial indicator on, added 0.090" shims under the pedestals to correct geometry issues and cobbled up an adjustable test pushrod.
with Proform 1.7 SBF rockers the valves just barely touch the pistons when the lifters are fully extended.
so any lash/compression of the lifter will give 1.7 times that as clearance between the valve & piston.
where I ran into the surprise interference with the stock parts turned out to be a wear pattern on the stock rockers.
normally the lifter would be compressed for lash and that determined how far the rocker traveled. there are wear "ridges"
in the rocker from the grooves in the stock pedestals. they acted as a "stop", sort of.
with the lifters fully extended the rockers traveled farther than normal and hit the "stops" (ridges)
since the chain was off and I was turning the cam by hand without much force I thought the valves were now hitting the pistons.
later I found that with more force I could rotate the cam & rockers past this "stop". actually, after going over the "stop" a few times
it sort of flattened out and went away. normal valve train movement resumed.
