need some more help
mkpecor
black diamond W.A.
ranger 4x4
2.9
88 2.9 ranger, well i got the heads on and drove it home from the old mans shop, ran fine all the way home. the next morning it started bogging out at higher RPM's, i have new ,plugs, cap,roter and plug wires. i checked all vacum lines all the rubber lines are new as well. if the throutle sencer was bad would it do this. any info..........
mkpecor
black diamond W.A.
ranger 4x4
2.9
im thinkin it might be the tfi
El_Capitan
Oregon
mostly 1987 but
2.9
You pull the codes yet? I doubt its the tfi... :beer:
jaymegriffiths
7
Regina,Saskatchewan
2.9
i checked all vacum lines all the rubber lines are new as well.QUOTE]
try sprayin propane near the vaccuum lines whiles it runnin and if it revs up you kow its vaccuum problem... if no check cats. or o2. dont know if this is accurate but the propane trick works sharp... also run codes and if you cant figure it out, pull the exhaust off for a minute and see if it still does.
IMenriched
4
NE Iowa John Deere country
02'
2.9 & 5.4
you might have a bad pick-up coil (hall effect) under the distributor.
have changed the fuel filter & air filter??
have you tried to pull codes??
mkpecor
black diamond W.A.
ranger 4x4
2.9
i changed the fuel filter last year the air filter i keep clean. i took it to schucks so they could pull codes, they didnt help much. when its could, like if i start it and take off it runs good, when it warms up then it starts to do this. it starts really easy like it has from day one.
IMenriched
4
02'
2.9 & 5.4
What were the codes??
you're right...at this point it could be a multitude of things...but your sysmtoms do hint of classic TFI problems.
while you were at you favorite parts store you could of popped the TFI off of it and had the test it too.
If I understand correctly....runs fine cold ,as soon as, you get warmed up and goes to closed loop..or is open?? anyway... when comes off the warm up/cold start presets and the sensors take over on management...then troubles start. with that in mind it would be lodgical to be a sensor issue.
mkpecor
black diamond W.A.
ranger 4x4
2.9
i put a new TFI on and same thing, so its not that, one of the codes read open spout, i checked that and its fine.
IMenriched
4
02'
2.9 & 5.4
double check connections maybe you have one that is...iffy?? exspecally grounds
have you back probed the TPS with analog multi-meter...& see if it swings voltage smoothly (no hic-up)from closed to WOT.
mkpecor
black diamond W.A.
ranger 4x4
2.9
here are the codes it ran. 67, koer, 18 spout circuit open, 77 wide open throuttle not sensed. what do you mean probe the TPS, i dont know shit when it comes to electronics. thanks for your help guys.
mkpecor
black diamond W.A.
ranger 4x4
2.9
a year ago i had it tested at schucks for some thing cant remember but that guy said my TPS was going bad, thats the only thing that came up. would my truck sputter and do this if the TPS was going out? i thought once they are bad they are bad, no?
mkpecor
black diamond W.A.
ranger 4x4
2.9
i put a new fuel filter in to day just to see if maybe it was that since i have run on E acouple of times and i really dont know whats in that tank, any wayz took it out and sure as shit if im givein it half to full throutle it starts cutting out, like its not getting fuel or spark . i broke down and said #uck it im done so to marrow im takeing it to a shop. i have never done this , i hate others working on my rigs but im done with it, want to say thanks to all that had info for me, thanks mike
