need help with grease gun
goldxlt
Constantia NY
so i bought my first grease gun today and just used it. it seemed easy enough but i got it stuck on the fitting...? i am assuming this isnt normal, what can i do, i allways thought i would just pull it off. it is a trigger gun with a flex hose and the tip has a ball in it.
chico4554
CT
maybe try to gently tap it off with a small hammer? It shouldnt get stuck.
skippy
38
Georgia,USSA
2.8l durasparked rice killer
+1,i grease a lot of bearings in my trade and the flex hose grease fitting gets stuck alot.they eventually break in,but they can be aggravating till they do.
kunar
131
Toledo, Ohio
5.8l
use a small flat head screw driver and try to pry and wiggle gently. it should pop right off if you do it right.
Turbo-T
Vancouver,Wa
2.3Turbo
The grease chuck is designed to clamp tighter under pressure. If you pump against a blockage in the zerk or bearing the pressure will hold it locked on the zerk.
pillen140
45
winston-salem, NC
push it on, then quickly pull. some times that works.:dunno:
goldxlt
Constantia NY
i got it off with the screwdriver, at first i was trying to be gentle, then i was getting tired and didnt care as much, doesnt look like i broke anything though:clapping:
martin
26
St Bruno, Quebec
1991
try pulling it off to the side as opposed to trying to pull it straight off.
merc2dogs
grand rapids michigan
explorer sport
Back off the tip a little by loosening up the collar for the first few uses, that generally keeps them from sticking so tight right off the bat. After a while it'll start to feel sloppy and you can snug it back up.
Ken.
