Need Advice On Getting a Headpipe
SykoRanger88
Purcellville VA
2.3l 4cyl
im gonna go to the junkyard here soon and get a few things for my truck, i might also get a newer style tube manifold from a 90s ranger, can any1 tell me what years to get and not get? or does it matter? anything i should look for when getting one? im not sure what differences they made to those headpipes and if theres a preferable year to pull it off of, thanks.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
93 and up I think have the newer style exhaust manifolds, but there are slight differences...you can use the Mazda B series from the same year if you can't find a Ranger because they are interchangeable...
Try to get one with that has the O2 sensor bung already on it if possible or plan to have to adapt by either using the lower pipe or having one welded on...
There was a few recent threads on this that might help you make a more informed decision...or at least prepare you for any extra work that may be involved...
Bryan22
4
So-Cal babay
94 extd
94 2.3
i think the ones off of the 93 and 94 have the o2 bung in the manifold.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I know the one I have does...and it came from a 93 B2300...
Z3CHYD
U.S. Military - Active
17
Lancaster, PA
3 front 5 rear
225/60R15
my 97 has a header, and the o2 sensor bung is welded to the pipe hooked to the header, im not sure if my header is stock or not though, the PO said it was aftermarket
SykoRanger88
Purcellville VA
2.3l 4cyl
alright thanks guys, just look for one thats got the bung for the o2 sensor on it and i should be good? i already went to junkyard but gdamn i only saw 1 90s ranger and it was almost a complete vehicle so i didnt bother plus i didnt know what to look for, i was hoping to get lucky and find a 90s ranger engine just laying around but i might go by there again and try to pull the header off that one ranger with handtools but that might not go well lol.
4b316
4
yes,get one from a 93-94.They have both bungs in them.As stated ,the 95-97,s have just one bung and the O2 sensor is in the down pipe.Not a big deal to put in,drill a hole for the sensor probe and weld the bung to the pipe.
SykoRanger88
Purcellville VA
2.3l 4cyl
booyaah went today and got one from a 93, its got a Bosch o2 sensor in it so im guessing its not an OEM one should i be able to use this o2 sensor or do i gotta buy a new one for my actual 88 engine? thanks
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
If it came from a 2.3 and it has two wires running from it you should be able to use it...check the connector and if it's not the same as yours just splice it into the wires and you should be good to go...as long as you splice the wires correctly it won't give you a CEL...
SykoRanger88
Purcellville VA
2.3l 4cyl
it came off a 93 2.3 ranger and i only see one wire which is for the o2 i guess i posted a pic up, ill compare them 2mara then go get a new exhaust gasket i guess.
SykoRanger88
Purcellville VA
2.3l 4cyl
quick question when i order the new exhaust gasket should i order it under 93 ford ranger which is where i got the header off of, or 88 which is the year of my truck? thanks
a-5 freak
23
Titusville, FL
2.3
They are all the same. that is at least what the guy told me at advanced. just get a 93 gasket and you should be fine.
SykoRanger88
Purcellville VA
2.3l 4cyl
cool, i gotta drill the old bolts out of the flange and hopefully my bolts off my manifold will come out ok so i can re use them.
SykoRanger88
Purcellville VA
2.3l 4cyl
im doing work on my truck got it lowered fixin the timing and havent put the headpipe on yet, but i notice that my EGR tube is a bigger diameter then what was hooked up to that 93 rangers pipe, and mine isnt gonna hook up without some modifications im guessing anyone run into trouble with this? also i notice the part where my EGR tube hooks to the exhaust manifold is leaking a little bit around that bolt, is that bad? im not sure if there suppose to be air tight, thanks.
