Need a new place to mount my antenna...
02RangerXLT
53
NE
The current hood/fender mount is rubbing paint off my hood, so it has to go... so I was wondering if this would work? A bar across the two sides of the bed.
Would I need to use a no ground plate antenna, or would a regular antenna and mount work since the bar is metal and the bolts would be too?
Thanks
17
mississippi
v6 3.0
just bolt it to the bed? forget the bar, just get a mount and bolt it to the front of the bed? right below the sliding window, where the antenna is drawn.
anchorshot
Tampa
V6 3.0L
If you continue with your idea I would use a no ground antenna.
02RangerXLT
53
NE
I'm not going to drill any more holes than i have to... this idea uses two existing ones.
02RangerXLT
53
NE
4ft... I held it up where it would go, and about 2/3 of it is above the cab.
Thanks
02RangerXLT
53
NE
02RangerXLT
53
NE
Well, I decided to just go with this idea, and I got the bar today. I'm going to run a ground wire from the mount to the frame to be sure.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
That's exactly how I had mine mounted before putting the rollbar in. Worked excellent (provided you have a full-length whip anyway. Shorter antennas you might have some trouble with the SWR on due to proximity of the cab).
02RangerXLT
53
NE
Alrighty, I got a bar made and got the antenna stud attached... I placed an order @ Right Channel Radios for a new coax and a spring, so hopefully by the end of the week I will have it tuned.
