My Current And Proposed Electrical Layout:
I pulled all of the cover plates from the wall outlets and switches. None of them had a Red wire in them except for the 20A 250V outlets for the AC units.
All of the outlets except two had a single 12-2 Romex going down the wall into them.
- The outlet over the window in the Front Room has (2) 12-2 Romex. I'm guessing this is where the lit sign that was in the TV repair shop window use to plug in and is controlled by one of the wall switches.
- One of the outlets in the Front Room (lower blue square on the partial wall) has a 2nd 12-2 Romex going to the outlet next to it.
The diagram above shows where all of the switches, outlets, and light fixtures are.
The brown square above the Rest Room is another propane wall heater, but this one has a 12-2 Romex going in to the top of it, and a thermostat on the wall. I will likely remove this wall heater. The other wall heater in the Front Room does not have Romex going to it. I'm going to ditch this wall heater in the Front Room and possibly add a small wood burner instead. Maybe.
You can see where I marked where I want to add a wall switch in the bathroom to work that light with the pull chain.
I've marked where I want to add outlets in the Mid Room with green boxes. I'll probably run the two on the wall off the one on the opposite side of the wall that ends that circuit. The other would be me switching the single outlet box under the Breaker Box to a larger bow with two outlets.
I've added a red box to indicate where I want a 220V outlet to go by the side door.
I've marked where I want to add outlets in the shop area with green boxes. One will be on it's own circuit for an air compressor to plug in to.
The diagram above shows how I want to reconfigure the lighting with LED tubes instead of the fluorescent.
Another note about the outlets. The conduit going up the wall from the outlet ends just above the ceiling drywall. It does not go in to a box. I'm guessing there's a junction box or boxes up there that distributes power to each 12-2 going to the outlets, since there's only on 12-2 at the outlet.
