My $3,500 Jaguar - The 'Mad Jag'
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
I haven't scanned the codes yet, buy the seller sent me a pic of the codes he got:
I've been trying to search online for possible solutions.
P0628 - Fuel pump A control circuit low. Sounds like this could be a poor ground, corroded connection, bad relay, or bad fuel pump.
P0171 - System too lean bank one.
P0174 - System too lean bank two.
From what I've been reading, having both of those codes at the same time can be air leaking at the intake / filter, leaking breather hose, or vacuum leak.
Jaaaaaaaaaaaaag 😎
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,799
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Uncle Gump
Token Old Guy
13,526
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Please tell me you've seen the Grand Tour episode, "Jaaaaaaaaaaaag"
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
I was looking at one once, but then did some research and found out some issues with the supercharged v8, and the fix was swapping in v8 out of a mustang. I dont recall the details, it was so long ago. The Jag was my buddys and wasn't running at the time, but he ended up getting it fixed...probably just shelled out a ton of cash.
Jim Oaks
Administrator
Supporting Vendor
8,799
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
71012
71013
Started to replace the upper control arm. The bolts come undone easily but unfortunately the air strut is in the way and won't let the bolt come out of the hole. If I'm going to have to see if I can drop the air strut and pull it out far enough to get the bolts out from the holes.
Is I also found that the tie rod end on the passenger side is pretty worn
71014
When the car sits for a few days it loses its air but once I start it up it raises 2-1/2 inches.
The right front seems to sit slightly lower than the left front when it's air up and I notice that the left front seems to have a newer air strut but I don't want to replace the right front air strut right now because there are 3 to $400 each
fastpakr
2,841
Roanoke, VA
Can the air strut be rebuilt?
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Welcome to luxury car problems. It's kinda like 1st world problems, but more frustrating.
Roert42
5,015
Kintersville, PA
Ranger XLT
4.0 SOHC
“Don’t buy that thing, it’s going to be very complicated to work on, need lots of repairs, and everything is going to be expensive.”
-“I bought this thing, why is everything broken, it’s a pita to work on, and why are parts so expensive”
I kid
Jim Oaks
Administrator
Supporting Vendor
8,799
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Jim Oaks
Administrator
Supporting Vendor
8,799
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I think the cost of repairs is why you can buy older Jags and BMW's so cheap. I figured with some time and patience I can address it's issues myself.
There's a coilover conversion to get rid of the air ride, but I like the air ride. This car is suppose to lower itself when you get it over 100 mph. 🙃
fastpakr
2,841
Roanoke, VA
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Yes. Because their typical owner needs a new vehicle every 2 years to maintain status, so that's only as long as they need to last. Flagship luxury cars are just test beds. Which leaves plenty of room to pack lots of buggy unnecessary technology and over engineering, for minor flashy features. because longevity is not an issue. Good times.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
I kid
Jaaaaaaaaaaaaaag 😎
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
The other side should wobble out with the wrench.. then you pull it out a bit and wobble the bolt pictured out.
