What about a 410 cam? Worth it? Do I still need the dual valve springs, or could I run it with stock? I think I would still need the 5.50" pushrods, which, even if I had the heads redone I'd likely need to replace some pushrods anyway.
I know that often the argument comes down to justifying the money spent, versus the horsepower gains, and the money spent versus doing a V8 swap.
Well its been at least 10 yrs since I owned that truck so im a little foggy on my 4.0 knowledge now....Im not sure Id run a stock spring with any aftermarket cam. On my 422 I went with what Comp recommended and just dropped everything for the heads off at my engine builders. I will say the power gain was very noticeable and in hindsight I think a bigger set of injectors and a tuner would have been a really good idea for that truck to take full advantage. Had the transmission issues not plagued the truck that would of been my next step for sure.
I try to focus more on whats the most reliable setup over whats the most power per dollar anymore. I have spent to many days and dollars fixing stupid little things on my of road trucks in the past that could have been avoided if I just spent my money smarter.
You have seen my truck and Im not embarrassed to say I am easily well past $10K into building it. Crazy? Stupid? I say no. But I spent the money in the best places I feel.
Bare bones interior with junkyard seats? Yep so I could spend $1k on good gauges and radio.
I spent over $2k just with DUFF so I knew my suspension was the best I could get. No junkyard parts.
I rebuilt my own 5.0 back to stock for less than $800 and only have maybe 250hp. Dumb? Not when that meant I could put the money saved into a bullet proof c4 trans Id never have to worry about.
I have $1500 RCV axles in my d44 and a full spool and Superior chromoly shafts in my 9". I have gotten crap from people saying it was stupid to spend that kind of money on those axles when I could have just used 1 ton axles. Well for a truck only on 35s I dont see the need for the bigger ,heavier,more expensive axles and now mine are 100% new with life time warranty on many of those parts. Worrying about my axles is the last thing on my mind when Im wheeling now.
Spend the money wisely and you wont care what the total is in the end. The reward is a truck that wont end up frustrating you and be so much more enjoyable!
