Motorcraft 2150A "feedback" carb?
ExploreNW
131
Mead, WA
Does anyone have one of these 2150A carbs on their trucks with the feedback equipment removed? Google seems eager to omit the "A" and show me 2150 info only; I can't seem to find anything on these carbs other than rebuild guides.
I have an E47E- -VA off of a Bronco II that will be going on my project truck without the EEC. I don't need the crazy vacuum tree either. I need to make a metering block to replace the air bleed solenoid with but I have no idea what size to make everything, or what I'm doing. I'm used to the 2100s that don't have any of this stuff.
There's also a vac solenoid on the float bowl between the power valve and fuel inlet. Pulled it; it is on a Y-shape flange with two tiny pinholes in the middle. Again, no idea what this is or does; or if it is essential on the 2150A or not.
Does anyone have a vac diagram for these?
Anything helps... Thanks!
19Walt93
4,482
Canaan,NH
351
3"
235/55R16
I have a 2150 off a 78 Mustang 2.8 that I rebuilt for my friend's Sunbeam that the engine went into, once I found the Offy 4 barrel manifold I put the 2150 in the box. I also have some old Ford manuals and will look up the feedback carb.
