- Aug 7, 2007
- 39
- Michigan
- Ford
- Engine Size
- 302, 2.3
- My credo
- If you're not making mistakes, you're not learning.
I have all the parts for my 4x4 swap and then some, and the other issues of the truck are getting to a point where I almost have to do a tear down for regular maintenance sake. Sooo much is getting to the point where I cannot put it off anymore. Thanks to several thousand miles with a misunderstanding of timing marks, this includes the engine. It doesn't have nearly the power it had with 3.73's even with 4.56's, and is getting a little rough running.
I have a 1997 2.3L, bone stock, somewhere in the 240k range (speedo gear was off for a long time), even still, 225k officially.
I'd like to keep the OBDII system.
Plan is:
factory block and accessories
2.5L crank/rods/pistons
enough re-bore to clean up the walls.
Deck enough to make things straight again (if necessary)
pre-94 roller cam
factory head/intake (ALL of it, including the silencer) But it will get a valve job and get all cleaned up
basic port match, knife edge the throttle body like in the tech section
Exhaust will be redone, probably 2.5" all the way back. But will roughly follow factory lines and will have a converter and a quiet muffler.
Would kind of like a full neutral balance, since I do have 4.56 gears and small tires. I spend a lot of time in the 3-4k range. But we'll see how much that's going to take (and cost).
The only other possible mod is a 5lb inertia ring for just a little bit extra low end smoothness, this isn't a speedster build, it's a truck build, moving and pulling.
Kinda keeping my fingers crossed for 160lb-ft+ and maybe 140hp.
Questions:
So will the factory OBDII system handle this? I haven't seen much during searching regarding the computer end of things.
Would I need something like this? do these even work?
http://jetchip.com/shop/chips-modules-programmers/jet-ford-module-manual-transmission-184/
I'm not very good and figuring out the injector thing, and kinda get a bit overwhelmed. Currently the truck has nearly new injectors, they're red. 19lb? will they be enough?
I'm assuming I'll have to do a little clearanceing on the pistons for the added valve lift? Is there enough meat on them?
Last one on Clutches: Kinda want something with a bit more holding power, but I don't want grabby. Know what I mean? Any suggestions?
Is there anything else I'm missing? I think I've got a pretty good handle on it otherwise.
Plan is:
pre-94 roller cam
Questions:
