Military Tires?
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
oatmealman
littleton, colorado
jeep yj 14b rea
5.7
ya,go for it but buy deuces first
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
well I once had a set of Military tires but I can't remember what they where. I can tell you I had them mounted on 20" double bead locks from USA6x6. they were 52" over all dia. and heavier than a pregnant elephant.
I believe the 14.00 R20 means it has 14" sidewall for mounting a 20" wheel, but 14.00 could also be the width????? why don't you email the guy and ask for a brake down of the sizes........
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
Hummers run a 37x12.5r16.5.
I can get them for like 125 a pop with 90% tred.
I'm thinkin this'll be my next set of tires.
There's a guy here parting out a 2.5 so I'm gonna see what he's got. Some rocks would be nice.
85_Ranger4x4
17,837
SW Iowa
With tractor tires the first number is the width, and the second is the rim diameter.
The 13.6-28's on my WD-45 are roughly 13.6" wide on a 28" diameter rim. If I had to guess this is how those tires are measured too.
Sidewall height is hard to measure because it varies with rim width.
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
What are the tires going on ?
I do not know Mil Tires what is the the ply rating on teh side walls ?
I would think that the side walls on these things will not flex very much with the weight of a Ranger, so unless you are doing MUD, MUD , MUD then the tire will be almost useless on the rocks or rough trails.
It may look good, the size vs $$$ but consider all aspects of what you want to do with the tires and "the look you want", then go for it, if it fits.
Luck,
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
yep, first number is the tire width, second is the rim size it mounts on. the US military style tread really sucks in most situations. they wander quite a bit in road driving. they do self clean well in mud, but the tread really doesn't propel you enough to get through any big mud holes. on rocks, i honestly don't know. i've driven everything from M38's and 151's to 5 ton trucks with this tread pattern. don't think i'd consider them myself. however, the new NATO tread pattern (Michelin ZXL and similar patterns) are much better and worth the extra money. just my $.02
