Math whizzes needed...
scooter
October OTOTM Winner
50
N.W. Oklahoma
5.0L
So the spedo in the Short Bus is 10mph off...
At 55, im goin 65mpg.
Sooooo how can i get a "close" mileage to get a mpg for this sucker????
I recorded the odometer readings at fill up, but i KNOW its not right. I can google map the mileages i guess.
Thanks!!!
Todd S.
cammeddrz
23
Ford/chevy
efi 350vortec
if it is reading 55, but moving physically 65. that is a 15.4% variation. meaning that you need to multiply the mileage shown on the odometer by .846 to get the actual miles traveled
you would then divide that number by the gallons of fuel used to get the MPG
4.0B2
151
Walls, MS
4.0 v6
shouldn't you multiply it by 1.154 to increase the mileage shown? since the odo is reading lower than acutal?
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Assuming 55 is actual mph and 65 is indicated mph then take your indicated mpg and times it by .848
I think that will give you actual mpg
Richard
4.0B2
151
Walls, MS
4.0 v6
but he said at 55 (on the speedo), he's doing 65 actually...
at least that's the way I took it.
regardless, he knows the way to do it now lol
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
If 65 is actual mph and 55 is indicated mph, then take your indicated mpg and times it by 1.182 for actual mpg.
cammeddrz
23
Ford/chevy
efi 350vortec
I got it backwards in my head, he should multiply by 1.182
what I had posted had been for if the reverse was true (i.e. if it said he was going 65, but was actually going 55)
allow me to clarify
the same relation can be shown in two different percentages (depending on which one you are comparing the other to)
65 is 18.2% larger than 55. (i.e. 55 X 1.182=65)
55 is 15.4% smaller than 65 (i.e. 65 x .846=55)
scooter
50
N.W. Oklahoma
5.0L
Changed the rear end gears to 3:77's.
Speedo reads 55 gps, navagaion and phone all say 65mph actually.
THANKS EVERYBODY!!!
cammeddrz
23
Ford/chevy
efi 350vortec
for that to be true, the rear end gears must've been around a 4.45 before you changed them?
scooter
50
N.W. Oklahoma
5.0L
Not sure on previous ratio.... It was changed right before i bought the bus.
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
3.2 before change?
edit; cammeddrz is probably correct. A bus would have low gearing.
cammeddrz
23
Ford/chevy
efi 350vortec
3.2 before change would cause the speedo to read faster than actual.
in order to have the speedo to read slow, he must've been shorter (numerically higher) on the gears before the swap
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Ah yes, I was still thinking of the way I first took the meaning of scooters post.
And I'm concentrating on baking oatmeal cookies so my brain isn't on the math so much.... ;)
Richard
gw33gp
Ham Radio Operator
538
Costa Mesa, CA
4.0 SOHC
33"
While the speedometer may be an indicator of how much the odometer is off, it does not give you a accurate reading on distance. My speedometer can be off 25% at low speed and 3% at high speeds. My odometer is off from 5% to almost right on depending on which tires I have on.
You need to know how much the odometer is off to calculate mpg. When I take a long trip, I zero my trip meter on my Ranger and on my GPS. From that I determine the percent error in my odometer and use that to calculate the actual mpg.
cammeddrz
23
Ford/chevy
efi 350vortec
^^ I agree.
for the record, GPS can be as inaccurate as anything else.
this is why the people who do distance-precise rallies install magnetic, wheel-driven speedometers. I have one of these in my truck. it is more precise than any gps that I have checked it against for speed (vs laser-radar)
and is super precise on distance too.
