Manual to electric transfercase swap
Kylew911
Virginia
Ford ranger
I'm wanting to know if a 1990 for ranger manual t case truck has the wiring for a electric transfercase hidden or tucked away some where. Swapping to a electric t case would solve 2 problems. 1 being I swapped to a dana 35, and even with 6in lift the drive shaft is too long going to the electric from the same donor would fix that issue. And the 2nd is do to the body lift the 4x4 lever is sunk in the floor. I already have the electric transfer case..
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
You have to look.
Some do some don't.
On that year I have seen NGS in a loop
:not_i::dntknw:
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Neutral gear switch
Kylew911
Virginia
Ford ranger
I pulled the center air vent and it has the plug for the switch. Where under the hood or under the truck does the wiring for the tcase plug
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Reg cab behind seat
Kylew911
Virginia
Ford ranger
Inside the cab??
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Yes.....in cab..
There is stuff in the tech library.
Shortcut. Look under truck and see if there is a tail tied back....follow from there
Kylew911
Virginia
Ford ranger
Theres no wires at the t case. I was asking if there is a master plug under the hood someplace for the t case harness. And theres nothing in the library for going from manual to electric. Only electric to manual
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Reverse that.
That simple.
The dash side RPO should be there. There will be a tie in in center lower dash and up where the switch goes. Rob harness fro. Truck in yard and it will be self explanatory
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
I have my bronco with me in pa....it's all exposed
I will try to put up some pics after work.
