Manual Locking Hubs
Scobi64
I have a 1999 Ranger 4x4. It had the stock automatic locking hubs. Vacuum operated. I have had problems with them. So I bought myself a set of Rugged Ridge manuals. They got good reviews and everything... I can't get them to stay in my truck! I've been through two sets now. At $200 a set I can't keep doing this. Any ideas on why they keep popping out while I'm driving? The truck has new CV axles and I tried replacing the plastic axle clips thinking maybe the axles were sliding in and out with too much play. Now RR is sending me a set for free due to my issue. Any ideas?
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
8
Plattsburgh, NY
1999
4.0. 4.0 Supercharged
are they actually locking? my buddy bought a set last year and tried to put them on this year.... yeah a year later.. well long story short, the splines on the inside are not machined corect. i believe its the splines for the shaft . so the hub would not slide on but instead push the ring on the hub creating tension thus popping off the bearing..
Scobi64
no that shouldnt be it... ive counted the splines. even before purchasing. unless im not understanding what you actually mean.
timbits588
Buffalo
2.3/4.0
That's really strange. I installed the RR ones on my '98 when I had it (probably 4 years ago now) and they worked perfect. Did you put on that little gasket and everything? If i remember correctly it took me a little bit to get it situated and snug.
hondaxr650
4
Tacoma, WA
How are the needle bearings that the axle spins in, inside the wheel bearing/hub assembly? I don't have any experience with the RR maunuals but I've seen the factory hubs pop out because the needle bearings were hammered and let the axle flop around too much.
Scobi64
The wheel bearings are also brand new. So that's not it, and yes I installed the rubber gasket as well. I haven't had any problems with the passenger side since I installed the second one. Maybe I'll just have to make sure that it seats better. I'm at the point where I'm ready to JB Weld or duct tape that freakin thing on there. I'll break it off if I have to some other time lol. I live in NH so I can't have an unreliable 4WD system in the storms. I have to drive...
Sampson
Milford, Mi
Mazda
I have them on my 99 and haven't had any problems with them. You could get a hose clamp that about the diameter of the hub and put it on the part where the RR hub mounts onto the wheel bearing with all the little fingers and tighten it down.
Scobi64
thought about the hose clamp idea. but using a CV axle boot clamp instead, so it doesn't have the bulge. i just received my new hubs yesterday. i installed it, drove around in 2wd for a couple hours, no problems. hit a trail, locked into 4wd, and within 3 mins it popped out. i spent an hour walking the trail with a flashlight, couldn't find it. so i installed the second new one again, on the drivers side... but i duct taped them where the plastic tabs clip over the hub. and then left them locked, and put closed center caps over them. if they pop out they aren't going anywhere... **** it
No members online now.
