Junk Collector
Truck of Month
- Mar 4, 2008
- 5,113
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
If you are only removing one bracket, you can leave everything on the other side in place. But if you are replacing both brackets then yes you will need to remove both springs.
Personally I think if you're happy with the ride height of your truck, there is no reason to buy new springs. They take 5 minutes to remove/install (maybe more if the bottom retainer is really rusty) so my advise is to stick with what you have and avoid excess expense.
You will need an alignment after you fix your bracket situation... factor in up to about $300 for that. Labor/bushings/etc add up. Hope it will be pretty close, I've gotten away pretty cheap a couple times and other times I've had to throw everything at it.
