M5OD tail shaft
chewy012
Colorado Springs, CO
4.0 OHV
Doing the clutch here next weekend. The drive shaft doesn't have a flanged connection to the tranny. Is it just a splined slip shaft that pulls out?
Also, if so, does the tranny need to be drained?
Sent from my XT1254 using Tapatalk
chewy012
4.0 OHV
Sorry, 92 4.0 5 speed 2wd.
It just pulls out. You don't have to drain the trans, but you will probably loose some fluid out the rear if you don't. Unless you can find the correct butt plug.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
If you're up on ramps you might lose some more, I didn't loose more than a few drips when I pulled my driveshaft a while back. But yes, it just pulls out and you don't need to drain it.
chewy012
4.0 OHV
I'll go peruse through my collection. Thanks for help guys.
Waiting for the parts to ship.... Ugh. Next weekend can't come soon enough
