facemaze
- Sep 7, 2020
- Reaction score
- 8
- Location
- Austin
- Make / Model
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3l
- Manual
- 2WD / 4WD
- 2WD
- My credo
- BirthTruckproblemsDeath
Gonna go to a junkyard and checkout the options. It can stay in the garage a while longer, but an upgrade has been on my list for a while now. maybe the universe is talking to me. Its a hard choice tho, I just did new bearings and seals 1.5 years ago. That job sucked.Hey there's a problem!
If you don't have any teeth missing or damaged on the ring & pinion, I'd be very tempted to just put new side and spider gears in plus a new pin if needed... my guess is the pin bolt broke or loosened up and fell out, this was actually kind of a common thing and there used to be a lot of threads about people running into broken bolts. Check the carrier and make sure the cross pin holes aren't egged out though!
Just have to see how chewed up everything is... a junkyard axle is an extreme solution if you can get away with just replacing a couple parts in yours.
I dont know shit about differentials. Open, Closed, Solid, L/S...... no clue.
